Pics of dual bucking spikes/dawgs
sawmikaze
1:15 AM
steeltown
Can any of you guys tell me where to get a set of dawgs for a 555/2260, I know guys were having trouble getting them every time they ordered for a 555/2260 they ended up with 562 sets.. which didn't work on the small mounts, they look the same but the mounting holes on the clutch cover were different.
Thansk.
Dieselshawn
1:15 AM
Southern Ontario, canada
Stihl MS 661C, restored:
View attachment 252108This saw was run over by a skid loader. You would not have wanted to see it after that happened. Somehow the case survived. Not much else did. I brought that and the rest of it back to life -- a resurrection.
I’m doing the same thing. I have two of them.
One is severely damaged by skidder and the other which is spinning the dyno has a tree fall on it when logger cut through the hinge.
F2EC6F4C-AE2F-434E-8F21-35816A7FE739.jpeg 9446D3A6-F902-431D-AAD1-ED9C309BE034.jpeg 59866082-6DAD-43C0-AFD9-AD713CC652FC.jpeg
Wood Doctor
Edwin
12:15 AM
Omaha, Nebraska
That last Pic could be a hopeless case because the case is history. Both of mine at least had a rotating crank shaft. The third Pic shows the worst damage to a saw that I have ever seen.
Dieselshawn
1:15 AM
I tore the saw down. If it wasn’t for a broken gas tank, impulse line and a bent out of shape coil, that saw could’ve ran like that.
The cylinder and case halves are still sealed even though the case halves are also broken beyond use.
8FF2DFAA-329A-4856-87B8-C36738F791E8.jpeg EF39F8E6-6BB4-4C24-8BBB-E9234FF8FC47.jpeg 0D850A37-0D84-4D0D-935E-FB2244CE4FEF.jpeg 899F965C-8EBC-4D56-8036-E1F4D4FEAABD.jpeg
Woodslasher
Teh debil
10:15 PM
Commiefornia
