Picked up a nice 044 yesterday
big t double
You can call me Teddy Eastwood.....
6:39 AM
BonScott46
1:39 PM
Sweden
Correct me if I am wrong but I seem to remember hearing that a straight fin cylinder will cause problems on a 10mm piston because of the position of the ring ends...course the saw has made it for a year after the rebuild and my memory ain't what it used to be.
junkman
Crush it
4:39 AM
pacific northwest
General rule is yes ,but there are a few out there running fine ,just depends how the intake port is for width .
7:39 AM
What would be the advantages or disadvantages?
That is a very early SN saw. It will have the smaller bolts for the recoil, and (as mentioned) be a black control lever.
Can you share when it was first sold? I try to equate the #s to rough dates. Mine starts with 126****** and I purchased it in Dec 92. It is a red lever slant fin KS and has the larger recoil bolts.
Another reason the 044s felt stronger/more responsive is because the mufflers were vented better from the factory, the hole was much larger.
TJ the Chainsaw Mechanic
Old Homelites rule!
4:39 AM
Shop I work at sold it on 3/09/1998 to a logger. Mine does have the smaller bolts and black lever.
7:39 AM
I just know my own saw as a reference point, and try and judge from there. By knowing when another saw hit the market, I kinda know the # of years a change in the #s make.
I should keep more organized notes of it. For example, I don't know exactly when they stopped using the D cylinder in the 046, but it was between SN 138****** and 140******. Wish I had an exact #, but just little stuff I store in my brain.
I also had an 044 that started 120******, and I know that saw (and prior ones) had black control levers and the smaller (4 mm ?) recoil bolts.
His # is very early, so I was curious. Wish I knew the # they started with.
The problem is, some saws were recorded, some were not.
I think the SNs when the bolts changed, and the control levers changed have been posted, but I don't recall them exactly.
