The instructions say to spray one side with Permatex Surface Prep activator and apply the sealant to the unprimed surface... Will it be OK if I don't use the activator?
It won't be fired for a few more days. I'd like to do a press/vac test to make sure everything is sealed. I'll need to make something to block the ports.
