Terry Syd
- 10:10 PM
- Jan 18, 2016
- Comboyne, NSW Australia
Yup, builds a fine saw too. I think the forums burnt him out....Mitch Weber is an electronical genius IMO.
Sadly....he not hang out wif us nomo
There is actually a thread on AS (I've still got it on my watch list, I can PM anyone if they are interested), where some guy hacks up a busted 056 ign unit and changes the blown capacitor. A labour of love, yes, but I guess that's the case with a lot of these projects.,you can't change or modify the internal components . So in a nut shell it either works or it doesn't .you can't repair it with one exception perhaps .
usually something with advanced timing is going to be harder to start.
so naturally i chose not to advance anything that i own.
now is part 6 fuel oil ratio mix?
Part six is gonna be on mufflers and tuned piped.
I think we have an oil thread of epic proportion already.
Of the decade lolBiggest understatement of the year.
If we are creating a situation where combustion is more efficient (i.e. making the squish band closely to optimal - less f/a mixture is wasted, and more is compressed in the combustion dome) then it seems likely that the charge will burn slightly quicker, and thus less advance of ignition timing would be required.Randy, my take on it is this. When we cut the squish band two things happen. One, we increase compression. Two, we improve flame travel in the chamber. We know compression makes the fuel/air charge more flammable and explosive. So it makes sense that a fuel mixture that's more explosive, and has a chamber design that the flame can travel faster would need less timing.
Yea, what I said, only fancier and more proper and stuff. LolIf we are creating a situation where combustion is more efficient (i.e. making the squish band closely to optimal - less f/a mixture is wasted, and more is compressed in the combustion dome) then it seems likely that the charge will burn slightly quicker, and thus less advance of ignition timing would be required.
If I'm not mistaken the 056 uses the same type SEM coil a 2100 Husqvarna uses which are very costly to find in OEM . When I was looking for one they were around $200 .I found one from Bryce in Washington state for $50 that the shut off circuit didn't work .I just taped into the high voltage lead and used a kill switch .There is actually a thread on AS (I've still got it on my watch list, I can PM anyone if they are interested), where some guy hacks up a busted 056 ign unit and changes the blown capacitor. A labour of love, yes, but I guess that's the case with a lot of these projects.
PMd you dude.If I'm not mistaken the 056 uses the same type SEM coil a 2100 Husqvarna uses which are very costly to find in OEM . When I was looking for one they were around $200 .I found one from Bryce in Washington state for $50 that the shut off circuit didn't work .I just taped into the high voltage lead and used a kill switch .
That might be the same guy I talked to from bend Oregon. This guy I talked to was assigned to ignition coils for his job in the military and learned everything about them. He told me the main thing that goes bad in 056 type coils is one little tiny wire that burns out and that they can be repaired.There is actually a thread on AS (I've still got it on my watch list, I can PM anyone if they are interested), where some guy hacks up a busted 056 ign unit and changes the blown capacitor. A labour of love, yes, but I guess that's the case with a lot of these projects.
