Oregon 33RWDD009
davidwyby
Rural desert logging
4:26 AM
Extreme Southeast CA
33” Oregon LW bar came with one chain. Don’t see DL count online. Instead of counting all the links I compared to a 32” 105DL and a 36” 115DL. I came up with 110 DL. Sound right?
Thanks
mrxlh
I stayed late and finished!
6:26 AM
Dat Boot
Thanks
DL should be stamped on the bar?
mrxlh
6:26 AM
Dat Boot
110 drivers for 3/8ths usually works perfectly with a 34" regular Husky or medium Stihl mount. So 110 in 3/8ths might be a driver or two too long for the 33".
Must be a similar deal with 28” bars, some are 92 some are 93, FWIW, the Tsumura 28” 92 dl takes a 93 dl just fine…
davidwyby
4:26 AM
Seems like it depends on whether it’s on a husky or Dolmar but I can’t remember which way.
stihl livin
Do the Dallas
6:26 AM
Upper Midwest
So I text mike and he ran a stihl mount rw bar with 110 drive links. He said they are the same length bars but the husky crack is set man farther then stihl so you lose an inch. He can’t get his login to work
mrxlh
6:26 AM
Dat Boot
Tsumura says 92 on the Husky, all my 28” chains are 93 and they work just fine. If I do run into a problem, I have a breaker and spinner as well. It was however a Makita 7900 that I had it mounted on so who knows. I do know that the Dolkita/Makmar bar adapter to large mount Stihl is different than the large Husky to large Stihl. Kevin @huskihl gave me a tip a while back, if you want DL counts to stay the same lay the bar that works on the one you are adapting too and make the slot length the same.
Squareground3691
7:26 AM
New England
Thanks
Yea , that’s correct 👍 on my Oregon LW bars
