fearofpavement
- 6:01 PM
- Dec 28, 2015
- Georgia
It drives me bonkers that nearly all the aftermarket sellers make no differentiation between plastics on the 029, 029S, 039 and the newer MS290, MS310 and MS390.
While a few of the earliest MS series saws had the flat top, almost all of them have the later style profile with the hump on the top plastics. All the 0 series plastics can be fitted to the MS series saws and vice versa but they cannot be mixed and matched. If one does a search for an air filter cover for an MS310, it will return the flat top version which will NOT fit the MS310. One would think that after making thousands of returns, sellers would catch on that there's two different styles with different part numbers.
Specifically the styles in conflict are the orange parts of these 1127 series saws. Also the air pre-filter is different as it fits under the differently profiled plastics.
There is an opportunity for an aftermarket seller to tap into this large market with the correct profile parts. That would be the rear handle, the air filter cover and the pre-filter. @definitivedave or HL Supply needs to get on this!
I wind up buying the pre-filters from Stihl as I've never found an aftermarket source. I won't pay $30 for an 0em air filter cover so I have a saw that is complete except for that. It's just going to sit there until I find an affordable solution.
Anyone else frustrated by this issue or is it just me?
