one saw that can do 20" and 16" bar?
r7000
12:52 PM
CT
I have an 18" poulan p.o.s. currently, considering updating to a husqvarna saw.
for what I use the saw for, and however frequently or infrequently, I think I'd like to have one good reliable saw capable of a 16" bar and a 20" bar.
Is such a thing possible, if so which make/model ?
12:52 PM
Yes I'm assuming even stihl 50cc and up will pull a 20"
I had a stihl 261 carbed version that did good with .325 20"
In hardwood
I have not run modern computer Husqvarnas
@Stump Shot you still have that 550 mark11?
wap13
12:52 PM
Ga
Husky 545/550 or 555/562 if wanting newer saw. Stihl 261, 362 or 400 will all do fine, though I would bypass the 362 and go straight to 400 if the money doesnt scare you as they are on the same chassis.
Ketchup
Epoxy member
10:52 AM
Colorado
If you want strong performance with a 20” bar on a stock saw, a 60cc is a better choice. Husky 357/9, 365, 562, Stihl 036/360/362/400, Echo 590/620. Any of those will handle 20” 3/8 chain. The only 50cc that I feel pulls a 20” acceptably in stock form is Stihl 261 (.325 chain). With skip chain a few other 50cc saws can handle 20” (346,550,4910) Any of the saws mentioned will pull 16” very well.
I believe there is a ported 562 in the for sale section. It’s a lot of saw for the money.
r7000
12:52 PM
CT
how does the 550 XP Mark II achieve 4.0hp where the 545 Mark II only 3.6 hp, with both being 3.06 cubic inch?
The 545 @ 9900 rpm vs 550 @ 10200 rpm, which I don't consider a significant enough difference that would allow for 10% more hp.
If I get the 16" bar version, was there some ultra light fancy bar available? That would be better at 20" length as an aftermarket purchase rather than getting the saw with a 20" bar? that sugihara link at the top here, they worth it?
Squareground3691
12:52 PM
New England
Transfer’s different,
r7000
12:52 PM
CT
what does "transfer's different" mean?
Duce
12:52 PM
Roscommon, MI
365xt vs 372xt, same cc, different transfer covers. Easy fix.
r7000
12:52 PM
CT
i watched
all set on "transfers"
Ketchup
Epoxy member
10:52 AM
Colorado
Most of the difference is in the transfer covers and the case stuffers.
HP ratings are deceiving. 550 looks strong on a graph, but in real use it’s performance is disappointing. Maybe it’s the elevation here but all the tree guys I know agree. 261 out cuts 550 and starts a lot easier. I wish it was the other way around, but it isn’t. 346 will be closer. Ported 346 is the very best.
Shop around for a light bar if you really want one. Ebay often has the best deals. Keep in mind that on a 20” .325 bar the light version only shaves a few ounces.
Chainmale
4:52 AM
Tasman New Zealand
The 545 is a slightly detuned version as a ranch/homeowner saw
Disciple of Monkey's
11:52 AM
I'm hardwood
Yes, I surely do, it's my go to. :) It's not a MKII though, last of the originals.
Woodpecker
Sassy Madam
12:52 PM
The important question is what do you use the saw for?
Chainsaws are stupid.
This guy… he gets it
r7000
12:52 PM
CT
cutting trees
residential
yard clean up
i should probably just get a 18" saw, and use one of those lightweight jap bars I guess
