Oilier adjustment for Lite Bars
redneckhillbilly
9:50 AM
NW MT
Just had a question after running my 592 with Husqvarna Lite Bar, the only saw with a Lite Bar I have ever ran, do the Lite Bars require a different amount of oil due to the difference in materials? I have the oiler turned up almost all the way and I dont really see the oil in the chain as much as I can with a standard bar, I know I know I am overthinking this, but what do others do? give them less oil, or more oil?
ammoaddict
11:50 AM
Granite Falls, NC
Check the oil holes in the bar. My guess is the older bar has bigger holes.
redneckhillbilly
9:50 AM
NW MT
the saw goes through oil, and I can tell the chain is oiling, but its harder to see it, maybe its just the stainless color of the bar that hides the oil better, I was wondering if by design they require a different adjustment than a standard bar, but it doesnt sound like that is the case.
5:50 PM
dangerousatom
11:50 AM
Quakertown, PA, United States
If you dont think ur getting enough oil during a cutting session but there is no sign of it ( burnt bar or excessive heat, wood sap gumming in the chain bits ) Try making a few long cuts and then quickly shutting down with no extra revs or throttle blips out of the cut. Take a new clean paper towel, tissue, even copier paper and and grab the bottom of the bar n chain and see it there is any evidence of oil on it.
It doesnt take much more then thin film of oil to keep things sliding right, its just a matter of keeping a continuous film going. If your familiar with your saw your eyes and nose will usually tell you there's and issue before the saw or your chips.
hacskaroly
2100 Fanclub Member
8:50 AM
Northern Idaho, Ehh
No, they don't require any different oiling adjustment than standard bars, just the type of wood being cut and size bar you are using (obviously, the longer the bar more oil you will need to get around the bar).
dangerousatom
11:50 AM
Im actually surprised nobody makes a high end steel bar with replaceable nose that is full hollow center with a single wall of 16g titanium thats punched and then vacuum brazed to the outer steel. It be stupid expensive :crazylick: ( $350 for a 24" Id wager ) but it would likely weigh less then 1/3 of a full steel bar.
Thinking about it, there may be thermal issues with such a small amount of steel and warping or long term heat cycle vs temper issues
gmrahn
11:50 AM
Savannah
Nice thread, I wish I’d have taken time to measure this but I believe the oil holes in TsuMura and Sugihara are slightly larger than the holes in a ES LT or a Canon. Does anyone have much experience with enlargement of the holes and the size upgrades. Thank you
iamsham78
Josh
11:50 AM
WVa
you can see the before and after, it really seems help keep the oil all the way around the bar.
redneckhillbilly
9:50 AM
NW MT
what I've noticed with the husqvarna light bars is that fines get into the oil grommet easier, I neve had it happen with standard bars, but since I've switched to light bars I've had fines plug up the oiler a few times, now it put a bead of grease around the gromet before I install the bar and so far it hasnt happend since.
lehman live edge slab
Live Action
10:50 AM
Mn
Must be because of it being a sugi hara bar since that’s who’s making the husky light bars
redneckhillbilly
9:50 AM
NW MT
i think they might be cut as small as spec would allow and that it doesnt leave much meat to cover the oiler grommet, just my theory.
Sloughfoot
8:50 AM
Norcal
The enlarged hole in the bar may just be less susceptible to clogging. The pump is going to put out what it does no matter what. It'll go to the chain groove or make a mess under the clutch cover. If you don't have a mess under the clutch cover it's all going to the chain groove. You have a dry chain and no mess the oil filter is clogged, are out of oil, line is pinched, a vent isn't venting if it has one or least likely the pump isn't working. And other reasons no doubt.
