Catbuster
Roadbuilder Extraordinaire
- 8:27 PM
- Dec 28, 2020
- Gateway to the South
The enlarged hole in the bar may just be less susceptible to clogging. The pump is going to put out what it does no matter what. It'll go to the chain groove or make a mess under the clutch cover. If you don't have a mess under the clutch cover it's all going to the chain groove. You have a dry chain and no mess the oil filter is clogged, are out of oil, line is pinched, a vent isn't venting if it has one or least likely the pump isn't working. And other reasons no doubt.
I fight this all the time with the ES Light, and new ES bars. I can’t even get a piece of 1/16” TIG wire through. I’ve opened all of mine up to around 3/32” drilled straight in and they’re much easier to keep clean, and flow more oil.
My Cannon & GB bars, on the other hand, have a larger hole to start and do much better.
