bikemike
- 1:28 PM
- Feb 4, 2016
- Cottage grove mn
Like a Harley it needs to leave it's mark
...on a clean concrete floor?
I'm going to have to give this a shot. The double sided foam tape didnt work. Its pissing oil. I enlarged the bar oil holes thinking if it had less resistance to get into the bar it would help but not the case. Unfortunately I probably wont have time to dive into it before I take it to MI for Buckin Stock. If I do it's going to be a long night.Common problem. Take the oil pump off, seal the inlet and outlet hose on either side. I also seal the large part of the hose that seals to the case. Be careful not to clog anything. I used black RTV. Everything has to be squeaky clean (oil free)
I’ve had the issue w my 357. Took everything apart, cleaned very well and used good sealant. It works for a while. Eventually back to weeping. So I replaced the rubber lines. I’ve been using the saw a lot lately and it is completely leak free. I’m chalking it up as a consumable part. Owned the saw since new in ‘11 and that’s the first time I replaced them. I did make sure that bracket squeezes the square part tight. Used OEM parts too.I'm going to have to give this a shot. The double sided foam tape didnt work. Its pissing oil. I enlarged the bar oil holes thinking if it had less resistance to get into the bar it would help but not the case. Unfortunately I probably wont have time to dive into it before I take it to MI for Buckin Stock. If I do it's going to be a long night.![]()
Um not any of my stihls and they sit in the hall way for 6 months over summer . I have never had a stihl leak now my 2 husky I called them Exxon valdez 1 and 2 (262xp 390xp) they leaked more than a drunken sailor ......Temperature changes create pressure in the oil tank and oil ooz out. Both stihl and husky sips. I dont say leak, but they sips a table spoon or so when stored for months.
Hm... I own a few low hour stihls, will sip a few drops a month from the adjust screw. My new 462 didn't run in yet and sip like 5 drops from 4 months of ownership. I drain the fuel but not oil, more than half full.Um not any of my stihls and they sit in the hall way for 6 months over summer . I have never had a stihl leak now my 2 husky I called them Exxon valdez 1 and 2 (262xp 390xp) they leaked more than a drunken sailor ......
Yeah, that's not the case. I have other saws that will get run time right along side my 2159 and not leak any oil like the 2159 does. All the same environmental conditions too. Its definitely a rubber issue.Temperature changes create pressure in the oil tank and oil ooz out. Both stihl and husky sips. I dont say leak, but they sips a table spoon or so when stored for months.
Did you add sealant to the new lines during replacement?I’ve had the issue w my 357. Took everything apart, cleaned very well and used good sealant. It works for a while. Eventually back to weeping. So I replaced the rubber lines. I’ve been using the saw a lot lately and it is completely leak free. I’m chalking it up as a consumable part. Owned the saw since new in ‘11 and that’s the first time I replaced them. I did make sure that bracket squeezes the square part tight. Used OEM parts too.
