NSP2. Cuz PA WiFi sucks
Status
Not open for further replies.
4:50 AM
I call BS.
It would take 3 days for you to get a work order, then order a disc, then get on the list to check out a grinder. Then youde forget to order a new face shield....
How you doin MS?
Pet Maddie for me. She has a hard life.
hows you slacker i figured youd already be in bed
Dream
4:50 AM
Elberton, GA
I'm good Dallas.
Was cleaning up a little more of my mess in the shop.
Had to give you a little *s-worde, or you'd think I was mad at ya.
Maddie eats better than I do. Susan tries to feed me green stuff. Says its good for me. I think shes tryin to collect on that insurance policy.
Found the house keys finally, so thats a good thing.
Dream
4:50 AM
Elberton, GA
lol were suppose to brass out grinders and i tell them im not doing it and never brass one out
this last outage the 2 of us had 3 grinders with different things on them
im ok coffee time
shes sacked out on the loveseat we was out today from 715 this morning until 9 something tonight
but she did get a jr bacon cheeseburger and some of my double from wendys
Yep. Need a wire wheel for cleaning and slag removal. Grinding disc for removing metal and paint etc.
Cutoff wheel for, you know.
DuratecMan10
4:50 AM
Florida
Reservoir. Ok. I'll check that, as soon as I find it. Maybe you meant the oil pan?
Anyhoo, its a 4R70W(old Ferd #AODE-W). Still has the integrated cooler in the Rad.
Lines etc are all good. Fluid is coming from rear of the pan area. Doesnt look like the pan gasket. Got that off and cleaned up. Looks like its gonna be the transfer case adapter to transmission(not using the word "tranny"" on purpose) gasket. Got one ordered. Gonna put new filter, gasket, adapter gaskets on both ends, and all seals while its apart. Fluid looks pretty good. Magnet in the pan had the usual fines, but no slivers or chunks.
Reservoir as in the dipstick and tube to check and to add trans fluid. Check that as well. Glad it's clean with no chunks, sounds like you'll be good to go pretty soon. How long ago did you change out that fluid? If it was some time ago might wanna change it out as well.
3:50 AM
o_O
4:50 AM
I'm good Dallas.
maddie is just happy i dont make her stay at the table until she eats all her veggies lol
exactly and on the last job the guy i was working with said he didnt like to weld and if i did all the welding he would do all the clean up and prep work
win for me
4:50 AM
we found the dipstick in florida
just dont know where the tube goes lol
Well....y'all are in for a hell of a ride.
lol we have our helmets on for the short bus ride
Dream
4:50 AM
Elberton, GA
So you mean the thing that the tube and the dipstick goes into, right? That would be called a "sump", or pan for short. The thing I took a picture of. Have to take that off to drain the fluid, since most dont have a drain plug, unless its an industrial or commercial application. Uhaul trucks with those trans do have drain plugs FYI.
YER KILLIN ME SMALLS!
Dream
4:50 AM
Elberton, GA
win for me
Didnt like to weld? Dats the easiest part of it. The prep and cleaning is what sucks. You scored big time slacker!
DuratecMan10
4:50 AM
Florida
Well where I come from they are called reservoirs, so open your vocabulary to different terms. I'd recommend draining and refilling the fluid, might as well since you're replacing gaskets and all.
Dream
4:50 AM
Elberton, GA
Maybe you should go check the "reservoir" on your girlfriend. That probably needs draining and cleaning.
3:50 AM
o_O
DuratecMan10
4:50 AM
Florida
I don't have any inflatables. So GFY
Status
