Jimmy in NC
- 10:26 PM
- Dec 23, 2015
- North Carolina
I dunno Brian...just noticed it today...i dont run enough to know. I'll start watching.
Maybe ill hit something other than a cable line today....
Crab picsIm going to be one hurting crab azz in the morning!
It was rough today. That base was 36" deep. I wouldnt be suprised if they went down to 48" with the concrete. It took 4.5 hrs to bust it out. It sucked cause you were on your knees most of the time.I really enjoy pouring concrete
Taking it out..... Not so much...
Not something everyone may want to do, but if you're getting say 75% chain life before you run out of adjustment, $6 for an 8 tooth sprocket for the remaining 25% is an easy fixThis chain may not stretch anymore...ran two tanks today and no tension change. I was just noticing I had less slot left than had been used this AM while cleaning the clutch area out and clearing the bar groove.
Normally I run an 8. Lately Ive been cutting piles pushed by track loader and excavator....went back to 7 for a bit extra torque and less damage from barb wire collisions.Not something everyone may want to do, but if you're getting say 75% chain life before you run out of adjustment, $6 for an 8 tooth sprocket for the remaining 25% is an easy fix
