- 9:13 PM
- Dec 29, 2015
- Ontario, Canada
Evening Steve. How's the snow situation?Not one single solitary thing.
Comes and goes. Melts and snows.Evening Steve. How's the snow situation?
Hey sweetie went to Lindseys friends house for a bit. Cleaned up round the house after that. About it, how about you?Sup cupcake? What did you do today?
PicsHey sweetie went to Lindseys friends house for a bit.
I slept in late today and then spent the rest of the day in the shop messing with a couple saws. Coffee n couch time now.Hey sweetie went to Lindseys friends house for a bit. Cleaned up round the house after that. About it, how about you?
Hey Kev, how's it going? What saws you playing with today?Pics
Put a bb kit on the 6421 raffle saw I won. Won't idle. Bought a 7900 cylinder off the bay to put on it. Not sure what's up. Tried 3 different carbs. Hoping it's the heavy piston and not the $100 coil. Pulled Dustin's 064 down to get timing #'s. Das about it.Hey Kev, how's it going? What saws you playing with today?
It's weird. Like it's under load at idle. Like a 36" bar with the chain too tight and a broken clutch spring. Let it below about 4k rpm and it dies.One of those in line LED spark testers are good for finding a low speed miss while running.
I wonder what color blue powder paint on a mag case burns in a bonfire
Have you tried a different spark plug? Just for something easy to tryIt's weird. Like it's under load at idle. Like a 36" bar with the chain too tight and a broken clutch spring. Let it below about 4k rpm and it dies.
You may need a different inlet lever spring in your carburetor, unless the diaphragm is too stiff to flutter properly.
3 carbs, 3 or 4 plugs, same resultsHave you tried a different spark plug? Just for something easy to try
I ran off a batch of home brew...same same.What about oil? Did you mix with Red Armor? That miracle potion cures everything, doesn't it?
Came from a running ported 7900 tho.Changing the carb, won't change the metering spring.![]()
Are you thinking it has something to do with timing?Came from a running ported 7900 tho.
