8:05 AM
Picked up the truck I bought off my niece a month or so agoIMG_20250712_103431374.jpg
I remember him buying this optima battery and telling me dave I'll never have to buy another battery for many years
I guess he said *f-word the terminals.
Free *s-wordty vicegrips for me
The truck has no AC
So I hung out in the beer cave a few minutes cooling down when I drove it home
73.00 in gas to fill if up and I put 5 gallons in it this morning
Neighbors steal gas from everybody there.
Tor R
Novice, Leg model #2
2:05 PM
Mandal
Today I have been a hopeless mechanic, I can blame myself for being very rusty.
560, Coil installed, I took it very easy with the carburetor, took the air filter part last, a little backwards but carefully. It went well so far.
Started up great, and then it started to run more and more poorly. Something was wrong and I didn't understand what. I put on a different flywheel, and that didn't help, not to mention all the times I have adjusted the coil. It spins well at idle, so to speak, but not as it should.
After an hour of pondering, I started checking the boot, and well, I hadn't tightened the carburetor screws, one had unscrewed completely, while the other was quite loose.
It is most likely so far out of calibration that the solution will be to reset the carburetor at MaskinSalg, more than enough mixture in the exhaust, at least that's what it looks like on the outside.
I took off the muffler to check that I hadn't burned a piston, and it was clean.
Tomorrow I'm going to redo the carb, just so that everything is 100% correct before I plan a drive to Evje.
Disciple of Monkey's
7:05 AM
It will fire up and run poorly until it adjusts itself out of its current state not to worry, I haven't seen one that didn't yet.
GCJenks204
"Special Buns"
7:05 AM
Winnipeg, MB
I reckon so...
The Wisconsin Department of Natural Resources has issued an Air
Quality Advisory for the following counties: Adams, Ashland,
Barron, Bayfield, Brown, Buffalo, Burnett, Calumet, Chippewa,
Clark, Columbia, Crawford, Dane, Dodge, Door, Douglas, Dunn, Eau
Claire, Florence, Fond du Lac, Forest, Grant, Green, Green Lake,
Iowa, Iron, Jackson, Jefferson, Juneau, Kenosha, Kewaunee, La
Crosse, Lafayette, Langlade, Lincoln, Manitowoc, Marathon,
Marinette, Marquette, Menominee, Milwaukee, Monroe, Oconto,
Oneida, Outagamie, Ozaukee, Pepin, Pierce, Polk, Portage, Price,
Racine, Richland, Rock, Rusk, Sauk, Sawyer, Shawano, Sheboygan,
St. Croix, Taylor, Trempealeau, Vernon, Vilas, Walworth,
Washburn, Washington, Waukesha, Waupaca, Waushara, Winnebago,
Wood.
WHAT...The PM2.5 AQI is expected to reach the Unhealthy for
Sensitive Groups (USG) to Unhealthy level.
WHERE...Statewide
WHEN...Now through 12:00 PM CDT Monday July 14th
Precautionary/Preparedness Actions:
Sensitive groups: Consider rescheduling or moving all activities
inside. Go inside if you have symptoms. People with asthma:
Follow your asthma action plan and keep quick-relief medicine
handy. People with heart disease: Symptoms such as palpitations,
shortness of breath, or unusual fatigue may indicate a serious
problem. If you have any of these, contact your health care
provider. Everyone else: Keep outdoor activities shorter and less
intense. Go inside if you have symptoms.
Additional Details:
Canadian wildfire smoke will impact all of Wisconsin throughout
the weekend. Initial impacts are expected to reach central
Wisconsin by early this afternoon, and southeastern Wisconsin by
late evening. The heaviest smoke is anticipated for locations
farther north, with periods of Very Unhealthy NowCast AQI
possible. USG to Unhealthy AQI will be more likely for central and
southeastern Wisconsin. The lowest concentrations are expected
across southwestern Wisconsin, where Moderate to USG AQI is more
likely. By Sunday, PM2.5 concentrations will be generally lower.
However, USG to Unhealthy AQI will remain possible statewide, with
higher concentrations more likely to the north.
For more information on current air quality, please see:
We’ve been 10+ since I woke up yesterday. The actual particulate count was almost 500ppm.
Tor R
2:05 PM
Mandal
It is also my experience that they calibrate themselves over time even after they have been far out of specs.
I will redo the carb assembly tomorrow, and give it another try, let it idle for a while. Just so I have eliminated that part.
Embarrassing to make a mistake like that though.
59billy
Unknown OPE Member
7:05 AM
MS
Picked up the truck I bought off my niece a month or so agoView attachment 464379
The truck has no AC
Don't have the right tool?
Vicegrips.
Don't have the right part?
Vicegrips.
Suspect won't talk?
Vicegrips.
59billy
Unknown OPE Member
7:05 AM
MS
Without embarrassing mistakes, would we even be human?
Tor R
2:05 PM
Mandal
Yep, that's very true, it happens, and it won't be the last time.
Now tomorrow will be much better, among other things it will rain, and the 560 will get a new round of Norwegian fingers caressing lol
Tor R
2:05 PM
Mandal
I have a spare coil and carburetor from 2014 that also comes from a 560 saw, and have updated software, carb reset.
It could also be the salvation today.
I would prefer to have the new one, but just as important to find a good solution.
Besides the 560, I will work a little more with the 234SG, and 357XPW.
234 gets a cylinder (hopefully piston is included) on Tuesday, the only thing missing for it is a gasket, air filter, carburetor HDA 12.
The only thing missing for the 357XPW is a meteor piston.
357 is the replacement for 254/262 at my place, I think it is a better saw.
On Monday I get a 242xpg in the mail, I thought it looked like a Gilardoni marking, but not sure until I get it.
I spent 5-6 years getting my first and only 242 with 241B cylinder, a friend of mine kept asking me to buy it, I gave it to him as a gift.
Later when he had his usual daily dose of alcohol, he traded it away for another chainsaw. I'm bitter, but that's life, positive and negative.
If this one has a 241B, I'll keep it for myself.
