Only the Tony
5:46 AM
It is a sign of calcium deficiency, which is also what is causing my tomatoes bottom end rot. While lime will adjust the pH, it does so slowly. I have been researching a liquid called agrigro super-cal, but am having a hard time finding application rates. I always take my time to thoroughly research stuff before I do it. I am looking for a long term solution, and it may be lime. Still doing research.
Adjusting the pH is great, but may not provide the calcium that I need.
We are gearing up to add a lot of lime. The lime we use comes from Albany Ky, and is 35% calcium.
Same problems in this area with the sage grass. Ag lime takes about 18 months to break down and be absorbed. I don't know of any place around here where you can get burnt/quick lime in any amounts. Quickest way to change the pH on soil, but harder to control because of the caustic properties of it. I probably need to drop about 5 tons/acre at parents and 4 ton on my place for a start. Nephew works for conservation department so maybe I can have him set up a prescribed burn late winter to help clean some of it up as well.
5:46 AM
I'm going to just bush hog all the fields down pretty tight, then pour the lime to it. Ag agent tells me to do 2 ton per acre this year, and 1 ton per for the next two years.
3browns
2:46 AM
Fishhook, Alaska
Full vegetarian dinner today !!View attachment 431826
Vegan John, not vegetarian.
My bad. But you knew what i meant.
I’m a vagetarian
Just to help you fellers out, cause God forbid you identify as the wrong kind of vegan/vegetarian/vagetarian
Plus GFAV
Woodwackr
4:46 AM
ID
Woodslasher
Teh debil
3:46 AM
Commiefornia
To all the Californians watching this thread, you're welcome. I finally got a haircut which guarantees that fall temperatures, at least rain, and possibly even snow will occur by the end of this week. It was a major effort on my part, but I'm happy to take one for the team.
