- 2:51 AM
- Oct 18, 2016
- GFY
Good morning fellas
International Smuggler. Kofoid running them last night for the big win ?Sold some bootleg spark plugs today...
Is that as loaded with sage grass as it looks?Cut some hay with the cub. Not sure the weather is going to cooperate, so hedged my bets and only cut some. View attachment 431799View attachment 431800View attachment 431801
Going to leave that half alone. Still have the front and also the back of the neighbors too. View attachment 431802
Some of our fields are eat up with it.Quite a bit yes. I cut the worst field first. We have possible rain in two days. My prime areas have none of the that, what we call broam (sp). Plenty of the stuff they like in this field though, just not in the pics.
It is a sign of calcium deficiency, which is also what is causing my tomatoes bottom end rot. While lime will adjust the pH, it does so slowly. I have been researching a liquid called agrigro super-cal, but am having a hard time finding application rates. I always take my time to thoroughly research stuff before I do it. I am looking for a long term solution, and it may be lime. Still doing research.Some of our fields are eat up with it.
We are gearing up to add a lot of lime. The lime we use comes from Albany Ky, and is 35% calcium.It is a sign of calcium deficiency, which is also what is causing my tomatoes bottom end rot. While lime will adjust the pH, it does so slowly. I have been researching a liquid called agrigro super-cal, but am having a hard time finding application rates. I always take my time to thoroughly research stuff before I do it. I am looking for a long term solution, and it may be lime. Still doing research.
Adjusting the pH is great, but may not provide the calcium that I need.
@redline4
They sure like the deer cane.
View attachment 431782View attachment 431783View attachment 431784
I hope so too Ed. I assume you have been seeing them as well? September 28th I will be in my stand. Bow in hand.Nice looking deer Larry.
Hope they stick around for you.
I may go that route too. You would think with all the limestone we have here, calcium wouldn't be a problem.We are gearing up to add a lot of lime. The lime we use comes from Albany Ky, and is 35% calcium.
