Lnk
Stock Chainsaws do not suck!
- 11:58 AM
- Oct 12, 2021
- East, TN
Which hotel did hey put you up in John?I could destroy a visa in this placeView attachment 423714
I still can't get the ignition timing exactly right on this 351. I need to pull the distributor back apart and loosen it up. Static timing has to be too high for it to run it's best on the road, then the starter wants to drag when it's up to temp.My Holley 670 Truck Avenger was the same. Haven’t touched it after bolting it on. Starts great, runs great.
When you say “loosen it up” are you talking lighter weight springs on the advance?I still can't get the ignition timing exactly right on this 351. I need to pull the distributor back apart and loosen it up. Static timing has to be too high for it to run it's best on the road, then the starter wants to drag when it's up to temp.
Yes.When you say “loosen it up” are you talking lighter weight springs on the advance?
Oh ya, and not even reach the second floor or basement. You thinking on getting into fly fishing or spin casting??I could destroy a visa in this placeView attachment 423714
During the big powder shortage, years ago, they were the best for late night online finds.Same here, of the 3 I have spent way more time and money in SW
I’ve only been to one and it was very much as described.Police funerals are about the saddest thing you’ll witness. The end of watch call the dispatcher puts over the radio is just gut wrenching. Sadly, i’ve been to too many. Friends of my Dad and such and now i’ll go to Brad’s.
What RPM are you checking timing at?Yes.
I've never checked it with a light above an idle. A Duraspark distributor has a preset amount of advance that you can set into it as you assemble the distributor. Mine advances mechanically 18° at the rotor, which is 36° at the crank. Add 6 or 8 initial timing and that's your total. The cam is small, and the compression is high, so I'm seeing too little total, if initial is low enough for it to start without dragging.What RPM are you checking timing at?
I have some spin casting equipment already. Fly fishing looks like the next adventure on the list. Some of it looks pretty affordable and some of it also looks like it's out of the reach of a normal person's budgetOh ya, and not even reach the second floor or basement. You thinking on getting into fly fishing or spin casting??
I'm staying right at the training center larry. They have dorm rooms here. Each student has their own room.Which hotel did hey put you up in John?
I have been fly fishing for over 60 years and as rabbit holes go, it can get real deep, real fast, IF YOU LET ITI have some spin casting equipment already. Fly fishing looks like the next adventure on the list. Some of it looks pretty affordable and some of it also looks like it's out of the reach of a normal person's budget
$150 worth of gear will take care of you for many years. Once you get good at it the pricier rods and reals do make things easier. Even then, you don’t need to get 80% of the hi-dollar crap to have a great time. After a while you discover a dozen different flies will do the job 95% of the time.I have been fly fishing for over 60 years and as rabbit holes go, it can get real deep, real fast, IF YOU LET IT
You can also have loads of fun with good affordable gear and some common sense
Yuppies drove the prices of gear up to astronomical levels, but that also drove innovation and quality to amazing heights, so thats a double edge sword
It boils down to the age old truth that a 100 year old 30/06 will still kill an elk or moose dead as a stone and you don't need a $2,000 rod and reel to fool a trout
Young whippersnapper$150 worth of gear will take care of you for many years. Once you get good at it the pricier rods and reals do make things easier. Even then, you don’t need to get 80% of the hi-dollar crap to have a great time. After a while you discover a dozen different flies will do the job 95% of the time.
You’ve got me by 2 years![]()
Unfortunately in custodyIn custody, or eye for an eye?
Looks pretty cold to me Sean. Those temps are all below freezing.
Morning Larry, I see you still have the hood up on the F250. Would that be something you may be sailing in the future??Looks pretty cold to me Sean. Those temps are all below freezing.
