redline4
I'm huge in Japan
3:45 AM
Rosholt Wisconsin
He hasn't been told if the cam is wiped or not
Ballpark how much do these usually run to fix?
He's looking into some kind of delete for that sequential or whatever it's called now.
I'd be completely making it up if I told you what the repair cost is on that right now.
The LT engines use what they call dynamic fuel management.
Look into a plug in device called the Pulsar LT.
I think you can turn that off along with autostop and change some over things. I think.
GCJenks204
"Special Buns"
3:45 AM
Winnipeg, MB
Unless you're hiding your money by buying a cruise liner, a new (first time in the water) pleasure boat just needs a name and some use Gaz.
Renaming an existing vessel has all sorts of superstitions.
We have ourselves a new creek cruiser on the way. Should have it end of the month.
full chizel
¯\_(ツ)_/¯
4:45 AM
USofA
what did you get? We see a cruiser at the marina when we go fishing on my buddies bass boat. Some woman owns it and its name is Alimony😂
I was looking at a Nitro bass boat a few years ago but i don’t have enough free time to justify the cost. Plus, we moved so i don’t live 1/2 mile from Lake St. Clair anymore.
GCJenks204
"Special Buns"
3:45 AM
Winnipeg, MB
We ended up going with a Seadoo Switch pontoon.
It will look something like this.
3:45 AM
Shows it to be a round cross section O-ring. This looks to be the correct cover for the valve.
Specifications​
  • Inside Diameter (MM): 16.3576
  • Nominal Section (MM): 2.209
  • Standard Number Code (alpha): A
  • Standard Number Size (alpha): 908
  • Material (alpha): H4D
Thank you Tony. I'll double check my oring sizes and make sure I'm using the right one.
