Firewood Hoarder
Just a firewood hack
5:29 AM
Wisconsin
Went back to look at your original picture. Is this just a shadow or a crack?
Is there supposed to be a flat washer in between the fitting and the valve body? Been awhile since I worked with hydraulic fittings, but I remember some of the ports had a washer in between the fitting and the boss on the port it threads into, to help comress and seal the o-ring
5:29 AM
No sir. Not according to the parts break down. My Massey 175 does have flat washers there.
Only the Tony
5:29 AM
A shadow I suppose. Looks like where it is counter bored on the face.
I was wondering about that. From the picture it looks like a line that travels across all the machined steps going from the fitting to under the dirt toward the edge of the housing.
5:29 AM
No cracks......just seeping out of the fitting where it screws into the casting. I'm going to cut about 20 acres of hay Monday. Once I get that done, I'll wash the tractor and pull off that floorboard so I can see it better. It might have a burr on the edge of the bore that damages the oring as it threads in. There's a good hydraulic shop in Crossville too....I'll take the fitting there and see if I can get a nylon backup washer to add a little more compression to the connection.
Firewood Hoarder
5:29 AM
Wisconsin
They may have an ORB (o-ring boss) fitting with a metal washer that will be a direct fit between the port and the taper fitting. Good luck, sir!
full chizel
¯\_(ツ)_/¯
6:29 AM
USofA
We spent 2 years scouring the used market and couldn’t find anything we were comfortable with buying. Hopefully this brings years of family fun and togetherness, can’t put a price on that…
Is that the one you steer like a jet ski?
My parents will be looking at boats when they get back up north.
