3:12 AM
I've got one of those coming apart right now.
He hasn't been told if the cam is wiped or not
Ballpark how much do these usually run to fix?
He's looking into some kind of delete for that sequential or whatever it's called now.
Only the Tony
2:12 AM
Shows it to be a round cross section O-ring. This looks to be the correct cover for the valve.
Specifications​
  • Inside Diameter (MM): 16.3576
  • Nominal Section (MM): 2.209
  • Standard Number Code (alpha): A
  • Standard Number Size (alpha): 908
  • Material (alpha): H4D
Kiwioilboiler
346 Pic Examiner
7:12 PM
Marsden Pt, NZ
Evening all. I need some advice from you fart smellers… What are the parameters for naming a boat? I know it needs one and once you name it you can’t change it? @Dream @Kiwioilboiler
Unless you're hiding your money by buying a cruise liner, a new (first time in the water) pleasure boat just needs a name and some use Gaz.
Renaming an existing vessel has all sorts of superstitions.
Lnk
Stock Chainsaws do not suck!
3:12 AM
East, TN
Good morning men, sunny Saturday morning. Nice an cool out there right now. Going to play in the garage for a while since it is nice and cool. Stay safe and have some fun today.
