Saw Collector
OPE Member
7:58 PM
Here
No the oil itself being under pressure doesn’t perform under pressure as designed. EP compound lubricant has attitive to withstand extreme pressure and still have foam strength I guess I worded my original post wrong
So you are seeing higher crankcase pressures than the 25-80 psi in the oil system. Interesting.
redline4
I'm huge in Japan
6:58 PM
Rosholt Wisconsin
@Slumberjack
This is what confused me. That last line. Oil pumps being like little hydraulic pumps and all, it made no sense that crank case pressure could overcome oil pressure.
Figured you would like this one.
Its microscopic air bubbles in the oil popping from the pressure between the crank bearings.
ray benson
6:58 PM
nw indiana
Could be another oil thread. Are some oils better than others to combat the oil issue?
redline4
I'm huge in Japan
6:58 PM
Rosholt Wisconsin
That bulletin pertains to diesel engines only.
Any decent rated oil is fine, and all seem to do what is discussed in that bulletin.
This is @P.M.P. oil thread, right??
p61 western
Ol Mudflap
4:58 PM
GFY
Seems like the ratings have gotten a little *f-wordy lately. Seems like the favored Delo and Rotella may not be up to par anymore. Oh and GFY Bish.
redline4
I'm huge in Japan
6:58 PM
Rosholt Wisconsin
Agreed.
It appears the oil companies are giving the end consumer a GFY courtesy of the EPA.
And hippies.
Cant forget the hippies.
And GFY back at ya Mikey.
