New Jonsered 2260. Muffler mod right away, or wait?
SOS Ridgerider
Muffler Modded Member
11:50 AM
Central CT
I have a new, never started, Jonsered 2260. This is my first electronic carb. I have heard the preferred method for getting the AutoTune going good, is to put it right into wood for the first 5 minutes. Is this correct? I know I will probably muffler mod it, so should I do it now, before I start it? Makes sense to me to do it now, so the AutoTune can compensate for it right away, but if there is a compelling reason not to do it I'll leave it alone for now.
Also, is there a thread for doing a MM on a 2260? I couldn't find anything. Same as a 562XP? I haven't even looked at it yet, but figured I'd start with some questions. Hopefully someone with more knowledge will chime in.
Thanks
rburg
10:50 AM
Tennessee
I have had a 562 for 2 years with a stock muffler. I would run it stock for awhile and see how you like it.
KenJax Tree
¯\_(ツ)_/¯
11:50 AM
Over there
Its the same as the 562xp mod. on my 2260/562 i opened as much as in could on the outlet and made the holes in the inlet 1 long hole.
CoreyB
10:50 AM
South east iowa
It would probably run cooler with it opened up. Might sound cooler as well. Lol
Simondo
4:50 PM
UK
If you need to be concerned on the Warranty then leave it ...if not...then getting some heat out of the front end is a good thing I feel . Never worked on the J red but have modded the 560xp for better flow. The Auto tune sorted itself out on the saw I did which was well used so dont see there being much of a bother retro modding if you were to leave it for a while.
SOS Ridgerider
11:50 AM
Central CT
Thanks for the input guys!
I'll just do the MM right off the bat then. I'm not concerned about the warranty. I do my own saw work, so I'll take responsibility if something goes wrong.
