dangerousatom
- 7:26 PM
- Feb 25, 2020
- Quakertown, PA, United States
Ok after the bone stock 550xp tossed a ring and chunked the piston and jug I bought a new jug and pop-up piston. I did an extensive port job without any timing changes and a gasket delete and rebuilt the carb. Before I did the muffler mod I decide to run the saw with muffler to see if it would start n idle without any issues….well it’s ridiculous!
It will start and run but only at full throttle and it’s barely running then. It will wonder up n down like 500-700 rpm ( by ear haven’t put a tac on it ) and only get up to 5-6k rpm at full throttle. I assume the wondering is the carb trying to make sense of what happed from last time running. I have ported both my 562xp and 565xp without issues and retuned the carbs via the let idle and then continued cut method with great success. I have also ported 7 other non electronic carb saws without any issues. This is just weird, any foresight advice or experience with this would be appreciated.
I do not believe there are any issues/vac leaks with the bottom end as the saw was running great until it just stopped as I let off the throttle while cutting.
