New here from Virginia
11:41 PM
Welcome to the site, and tell me what your planning for your 460. I have 3 046/460s in the works, and a ported one that is STRONG! (It's Dr Al's fault)!
Will be happy to help you with any questions you have, or how to accomplish things w/o the proper tools!!! (and, what you just need to get).
Recently got one going with a Meteor piston and an HL Supply jug that I did a little port work to myself, and it runs very nice. No machining!
GlocknStihl
Derelict OPE Member
11:41 PM
At God's feet
I want to use an OEM cylinder, and I'll clean the intake and exhaust port a little. I'm not confident enough to touch transfer ports lol I want to use an oem or Meteor piston.
I've already got a standard and big bore Hyway kits, and I test parts for them. I just want it to come out making stock power at least. It's to hold me over until the 462 gets here (3rd quarter of 2019).
RIDE-RED 350r
11:41 PM
Blossvale NY
Hey leave him alone I tell you!
I see you are using my own pictoral intimidation material against me...well played Sir! :D
11:41 PM
OEM or Meteor piston are both great, as is OEM cylinder.
Try a test assembly w/o base gasket and check your squish, it often works.
Make or buy a timing wheel and check the port #s. Often on a 460 will benefit a lot from lowering the intake port, which you can do w/o any special tools.
After doing all this work, you don't want to get out run by a 044/440!
GlocknStihl
Derelict OPE Member
11:41 PM
At God's feet
Thanks, I sent you a PM about it. My 360 is running with no base gasket, squish was .023".
jacob j.
Only the weird
8:41 PM
Coastal Oregon
Well I wasnt going to share my chainsaw secret,but now I will. I mix 116 octane leaded racing gas 20:1 with astroglide. Cant go much richer though, it's so slick the piston will go out the exhaust port.
I think you'll fit in well here.
XP_Slinger
They’re Just Saws
11:41 PM
Central NY
I literally LOL’d at this. You’ll fit right in around here, welcome to OPE.
#feckoilthreads
