- 4:11 PM
- Jan 12, 2016
- Iowa City
I thought TM always liked to make them level???
I think his 066s dynoed higher than any I have seen.
Maybe he was giving you misdirection.
Scott did always tell me he went flat across, I believe you are correct Mike.I thought TM always liked to make them level???
I did the transfers like you suggested, now the exhaust side opens at 116 and goes to around 118 on the intake side. That would give me 20 degrees blow down.They do pretty well at around 23deg blow down, so you only have to raise the transfers around 0.020". Hopefully you can get the port stager in there, open the ex side first by 0.015" ~1.5deg opening.
I got the Hyway Titanikel plated cylinder, nice looking cylinder. I'll post the timing numbers taken with a ring in a few, the EX number I took with my eye on the Neotec cylinder was off a couple of degrees and it ended up being 94 with a ring, not 96.
View attachment 302517 View attachment 302518 View attachment 302519 View attachment 302520 View attachment 302521
I'm glad the numbers are good because from what I've read the plating on these chip bad when you grind on them. I've got a kit saw on the way and I'll put it on that one the way it is.Wow, real nice #s, and a good looking cylinder, except the squish!
I think I would delete the base gasket, check the width of the Ex and In, advance the timing and run it!
Good to know, thanks.I use a dukes pop up in a saw , and haven't had any issues.
I don't own a little scale but the Dukes piston felt significantly lighter than the oem, I didn't think the machining quality was as good as meteor but definitely working.Good to know, thanks.
I was just looking at the Duke's piston, it is very light and the skirt is a lot thinner than the Hyway.I don't own a little scale but the Dukes piston felt significantly lighter than the oem, I didn't think the machining quality was as good as meteor but definitely working.
Materials are improving and engineering.I was just looking at the Duke's piston, it is very light and the skirt is a lot thinner than the Hyway.
I hope that's the case.Materials are improving and engineering.
One way to find outI hope that's the case.
