Need a little porting help with a Hyway 272 cylinder.
Ronie
10:05 AM
NC
Little background. I have an older white top 61 that I put a Hyway 272 cylinder on. The squish is .0195 and I opened the exhaust up 3-4 milameters and lowered the intake to 79. Compression is a little over 150psi cold. It just doesn't run like I feel it should, lacks torque, so I'm going to cut a .040 pop up and shorten the blow down to maybe 18, it's at 20 now. Any suggestions would be appreciated. As it stands the timing numbers are,
EX 100
IN 79
TR 120
I've went through around a tank and a half trying different tunes and this is the best I could get.
srcarr52
10:05 AM
Iowa City
In my opinion you have too much exhaust duration to make decent torque on that platform. I'd say get the squish band cut and lengthen the exhaust duration but you already have too much intake duration as well. Ditch that jug and start over or commit to filling the intake floor with epoxy.
Ronie
10:05 AM
NC
Thanks for the input. I don't mind using a little JB Weld on the intake. Do you think a shorter blow down would help it out any?
srcarr52
10:05 AM
Iowa City
A little, looking back at my notes it seems I favored around 18deg blow down, exhaust around 102 and intake around 77.
Disciple of Monkey's
9:05 AM
If you didn't do any area work on the intake you can get away with more duration, both just won't do, so it's hard to answer the question directly if that makes any sense. If this is the case I would run it first without adding epoxy if in the low low eighty's.
I think the the guys have got you on the right track here. 103-104 exhaust is a great work saw target. This said you should have a screamer on your hands(play type saw) now, the compression is low in my experience with stock cylinders. I would recommend going over your cylinder with a fine tooth comb and check for it being out of round etc., if you find anything suspect, it's really not worth your time investment. If this ends up being the case(which I suspect it is) I would highly recommend finding a OEM cylinder to work with, used with a Meteor piston is a good money saving option, or a new kit which is not much more than the AM now days.
PogoInTheWoods
10:05 AM
Ohio
Or try a different carb depnding on what's already there. Opening up the intake block itself (with the right carb) will provide significant additional gains regarding flow. If it has a larger venturi carb with the original older intake block it'll be pretty choked up to begin with regardless of what you do to the intake (porting-wise).
May want to put a different ring in it, too. 150# is kinda low for a fresh top end on one o' those..., especially given the squish you have.
Don't know much about porting numbers, myself. Just considering other possibilities before the epoxy and re-grinding if you haven't already covered those bases.
Ronie
10:05 AM
NC
Thanks everyone for your help. I'm going to do like srcarr52 suggested and go with an OEM cylinder. I've got a couple of 670 cylinders and couple of new Meteor pistons so I'll use the numbers that huskihl posted with one of them. I also have a NOS 670 carb I can use on it.
Ronie
10:05 AM
NC
You're probable right about that cylinder, somethings not right and I'm better off going OEM.
David Young
Safety First !!!!!!
10:05 AM
vt
The 670 wont work easily because the 670 has a different intake arrangement with a rubber boot
Ronie
10:05 AM
NC
even a oem 266/268 jug would be better in my opinion. but it will also have a different intake than the 272
I have a 266 cylinder I could use but it looks like someone lost a clip and it cut a couple of gouges below the upper transfer on one side. I'm saving it for a backup.
srcarr52
10:05 AM
Iowa City
Before you mess with any of the porting... have you tried advancing the ignition timing a bit?
It seems a little lazy upon spool up which is normally be an indicator of too much intake duration... but it can also be lack of timing.
