- 6:42 PM
- Dec 24, 2015
- Coastal Oregon
I wouldn't go with OEM Stihl clips in a Husqvarna piston because Stihl pistons usually have a little "relief" area on the wrist pin boss where you get the clip started and most Husqvarna pistons (even a/m) don't have this.
Yes, not all a/m pistons will be compatible with any OEM clips but there are great variances in a/m pistons (even among early and late versions of the same "brand").
The rule of thumb is: if you can use an OEM clip and it's a good fit, then go that route. Same with wrist pins- and some OEM Stihl wrist pins are a better fit in OEM or a/m Husqvarna pistons than OEM Husqvarna wrist pins.
