- 2:14 PM
- Dec 28, 2015
- Central Ohio
F dem solos, I think I see pair of 064 hellcats on that bench!!!!
Back in the day....there were WildThing build offs on AS. Those vibrating little jokers can run but you better bring your "A" game to build one....nuff said really get ahold of yourself pop pop .... So.... Did you chase those baby bulls down? I feel like we need to make this a cattle thread ??? So you ever port a wild thing? I be owning one but I don't know if I have time to fool with you if you're excuses are gonna stand In the way of such a fine saw. Can you make one keep up with an xp? I want 70ccs comparability get your ass in gear!
I might also add:
Have you considered using crack? You'll be much faster at taking saws apart and then forget all about them, problem solved. Good luck sir!
The beatings will continue till morale improves.I might be slow..........but I do some damn *s-wordty work. So that makes it ok.
It worked for Moody.I might also add:
It worked for Moody.![]()
I prefer Biofreeze, way better than icy hot IMO. There just isn't anything that I've found that works better. I strongly recommend giving it a try.try some icy hot on your pulled muscles it helps.
Not even if can't get right rubs it on?I'm not using either of those next to my sack. I use an ice pack in the evening sometimes........
How do you tell if it your work that smell or the cow chit on your bootsI might be slow..........but I do some damn *s-wordty work. So that makes it ok.
