cuinrearview
Handy dood
- 12:17 PM
- Apr 16, 2019
- Dowling, MI
Dot dot dotI'm equal parts introvert extrovert.
The fact that you know my name without me telling you is more concerning than the possibility of having you refer to me by my full name, but whatever.Daniel it is.
Never show a weakness bro.
He doesn't worry me, YMMVThe fact that you know my name without me telling you is more concerning than the possibility of having you refer to me by my full name, but whatever.
Who?Ah, imagine you showing up.
This stuffed saw is more likely to be Emissions Complaint than Emissions Compliant isn't it?
+ Dibz on the used plumber’s tapeSo to actual 357/9 stuff....
I was incorrect in saying there are two versions of case. There are three in my possession, but that only came to light when I split the box of five cases yesterday.
Between the early and later (V2), I discovered today some V1 labelled cases on '04 and '05 dated saws.
More ribs and gussets as each version was cast according to my eye.
In the pics below, V2 at top, V1 middle and original bottom. My pick is pointing to the added material around top cover locator and brake handle. You'll have to roll back and forth, I don't have the technological skills to create a close up of three items in one picture sorry.
What's it all mean? Get later cases if possible if you are re-casing, they're cast stronger. The V1 has the bar stud reinforcement that original does not, so are better, V2 adds a bit more again.
View attachment 337760 View attachment 337761 View attachment 337762
Sure. You've earned it.+ Dibz on the used plumber’s tape
Dan-yuuuuul!Thanks! Fyi, I prefer “Dan”, hearing my full name makes me think I’m in trouble.![]()
Got given a 357xp last week, scored cylinder and missing parts. Was just about to order everything and read this!If all this case info has you all flustered, there is an easy way to check which cases your saw has, as I discovered on my 03.
If a part no. can be seen under the bar pad cover on the PTO side as indicated, then you have V2 cases. Worry no more. (Unless you too have a great big blobby weld for an AV mount...).
Something regarding this is referenced in the ipls, but not in a way I could understand.
View attachment 326698 View attachment 326699
The "Gravity" saw has a usable cylinder. I finger emery sanded the transfer off and its done a few hours since. Is missing a few cooling fin parts tho, but the cylinder will be "spare" at some point. Don't really have any other bits because i bought complete, damaged saws, and all three are going back in to service in some way eventually bro.Got given a 357xp last week, scored cylinder and missing parts. Was just about to order everything and read this!
Made me jump out of my chair and go check..... Whew a, lovely set of numbers staring back at me.
Don't suppose you're parting with any bits from your collection?
Fair enough, I may be able to save the cylinder. Whoever gave it to the person I got it from started stripping it down so it's missing clutch cover, muffler + bolts and bracket, top cover, and a very confusing at first throttle linkage. Plus needs a piston. Can get most of it from chainswr in the states other than top cover, clutch cover, and muffler bolts and bracket. For just under $200 delivered, including new genuine piston and gaskets filter and hose. So just waiting on Mr sky blue on trade me to reply with a cost for the rest to see if it's worth going ahead with.The "Gravity" saw has a usable cylinder. I finger emery sanded the transfer off and its done a few hours since. Is missing a few cooling fin parts tho, but the cylinder will be "spare" at some point. Don't really have any other bits because i bought complete, damaged saws, and all three are going back in to service in some way eventually bro.
The blue strap is holding the saw into the corner of the ute so it doesn't go a-wandering Sean....I guessing that strap-on is holding the cover on.
but I can’t fathom out the other thing ? Is it a saddle or a hand cover![]()
Either way, it all sounds kinky to me.I guessing that strap-on is holding the cover on.
Came across (ok, won in an online auction) another one. Let's see what we can learn from it...
