My 357xp musings.
Kiwioilboiler
346 Pic Examiner
3:38 PM
Marsden Pt, NZ
In all cases, the part no. cast in is the same:
503 92 53 PTO and 503 92 57 Starter.
Only the newer cases have the V2. Which I'm guessing indicates Version Two.
Kiwioilboiler
346 Pic Examiner
3:38 PM
Marsden Pt, NZ
If all this case info has you all flustered, there is an easy way to check which cases your saw has, as I discovered on my 03.
If a part no. can be seen under the bar pad cover on the PTO side as indicated, then you have V2 cases. Worry no more. (Unless you too have a great big blobby weld for an AV mount...).
Something regarding this is referenced in the ipls, but not in a way I could understand.
Woodslasher
Teh debil
6:38 PM
Commiefornia
Got back to these today.
Anyone seen a serial tag like this before? It's got a build date, but also seems to reference an earlier legislation or something.
@jacob j @PA Dan @anyotherhuskyguy ?
You’re upside down, things may have been “special made” for NZ for awhile. On a slightly related note, I’ve seen a few early 2000’s Huskies that say they meet Aussie emissions standards and DB standards on the tags instead of saying they’re US compliant. Maybe the lands down under put out a short lived law that caused Husky to revamp some of their machines for awhile?
Woodslasher
Teh debil
6:38 PM
Commiefornia
Well, a brief search led me to an AU website that listed a 550 for sale and here’s what the spec sheet told me: So, it looks like it’s an “emissions compliant” badge.
Emission data EU
HC, g/kWh 58.92 g/kWh
CO, g/kWh 254.39 g/kWh
NOx, g/kWh 3.64 g/kWh
CO2, g/kWh 883.26 g/kWh
HC+NOx FEL, g/kWh 72 g/kWh
Approval certificate number (Emissions) e5*97/68SH3G3*2002/88*0147*00 (II)
Kiwioilboiler
346 Pic Examiner
3:38 PM
Marsden Pt, NZ
Emission data EU
Nice Google Fu Daniel.
