My 290-390 conversion thread
STOVE
10:28 PM
Eastern NC
A friend of mine texted me a photo of a ms290 he found cleaning out his parents house after they passed. I was gracious to have any saw to work on and accepted.
Decided to order the 390 jug and pop up from Sawsalvage. I plan to do some light grinding work. My first time doing that as well as my first complete tear down. The entire saw needs a deep cleaning while chasing before any reassembly
Many members have given me great advice thus far. I wanted to chronicle my build for any others tearing down the 1127 series.
So far the hardest part of teardown has been the rubber mount holding the handle to the case. I have slowly torn it down, placing parts and their screws in ziplocs with sharpie labels.
hacskaroly
2100 Fanclub Member
7:28 PM
Northern Idaho, Ehh
More photos of filth
Yup, I have worked on many saws that looked like that, need to be an archeologist to dig the saw out of the dirt encasing it.
Smart man!!
STOVE
10:28 PM
Eastern NC
Updates. Got some of the parts clean, top end and crank removed. Had to soak the jug bolts in PB overnight.
Ran into our first fiasco. Going to have to run a die over the bar stud to attempt the double nut removal trick. Other than that things are progressing fine.
Going to clean up the muffler and give it some breathing holes. Will do some light grinding on the jug this week. Hoping to have everything ready to reassemble by the weekend.
Also does anyone have a creative name for the oil/dirt/sawdust crud that ends up all over saws?
STOVE
10:28 PM
Eastern NC
Finally got the bar stud out today. Had to cut new threads on the top half.
I will start grinding in the top end, and finish the muffler mod soon. Assembly will begin Friday night
A side note, a member of the forum has been super helpful via email. His name is Herman. He is going through cancer treatments and has been communicating with me despite it all. OPE name is @fearofpavement
I cannot thank him enough for his help.
STOVE
10:28 PM
Eastern NC
Took the leap tonight into grinding the jug. Fell asleep in my daughter’s room putting her down. Walked downstairs around 11:20. Phone call from the wife at 12:10
“what are you doing”
“Working on that saw”
“It’s midnight”
“Yep”
all went pretty well. I will take some nail files and try to soften the upper edge. I got as much as I felt comfortable doing. The sharpie lines are 33mm
Used a dremel with flex attachment, cheap amazon burrs and 1/4 sanding drums
singinwoodwackr
8:28 PM
moon
Uh…gunk? 🤣
jacob j.
Only the weird
7:28 PM
Coastal Oregon
@fearofpavement is one of the good old boys for sure.
STOVE
10:28 PM
Eastern NC
Got the exhaust done tonight, tried my best not to touch the op or bottom much if at all.
Then came the big hang up. I cannot get this crank and piston into the top end. Taking a break from it now. Kicking myself for applying gasket to both halves ahead of time. Will have to clean both and retry later this evening. Was discouraged enough to backcheck my Dukes order to be sure I didn’t order a 290/310 jug by mistakeIMG_1458.jpegIMG_1457.jpeg
singinwoodwackr
8:28 PM
moon
Then came the big hang up. I cannot get this crank and piston into the top end. Taking a break from it now. Kicking myself for applying gasket to both halves ahead of time. Will have to clean both and retry later this evening. Was discouraged enough to backcheck my Dukes order to be sure I didn’t order a 290/310 jug by mistakeView attachment 479967View attachment 479968
There is a ring compression gizmo you need for those. Pretty cheap on eBay.
STOVE
10:28 PM
Eastern NC
Still waiting on my 1127 ring compressor to arrive and I had a thought.
I’m constantly running my fingers over the inside of the ports to convince myself they are beveled enough. Would putting a ring in the jug and pushing it up be a solid test?
CrystalRiver1
9:28 PM
Alabama
Hang in there Herman...blessings & swift healing your way brother!
