ms880 clone
Fleethirte
4:08 AM
Virginia
Cylinder looks decent in my opinion!
Fleethirte
4:08 AM
Virginia
Stainless steel muffler!
Fleethirte
4:08 AM
Virginia
Crank case. I got one side of the crank in.
Absolution
4:08 AM
WV/NC
That 880 cylinder I had got from them originally looked better than that one...... I hope the squish and timing is good.
4:08 AM
Looks good, keep us posted!
Will be interesting to see if that imitation Elastostart holds up .... I have had VERY BAD Luck with them in the past!
Seems like they keep making improvments.
Yea, I think that hole is for a top cover mount also! (Like the 461 has).
Fleethirte
4:08 AM
Virginia
I got the crankcase put together. Whew those bearing and the crankshaft are definitely bigger and stronger then the 660. I had a rough time trying to get the crank centered. I had to do a lot more then just tap the crank. Almost was going to find a press…
But I let some oil seep in overnight and finally got
It moved into the sweet spot this morning.
Fleethirte
4:08 AM
Virginia
How do you route and hook up the gas line and impulse line? Doesn't seem as straight forward as the 660…
Mattyo
Youtube speciawist
4:08 AM
Farmington, CT
sounds like u need a toolset for crankcase assembly ;)
mirage
2:08 AM
idaho
Thinking about buying a 880 kit. Is there a list of parts that I need to buy so the saw will be dependable? What about the crank tool? Where can I get this. I would like to buy from a USA dealer. Is there a USA dealer who has all the better parts that need to be replaced?
Jason628
1:08 AM
Washington
It probably has same issues that 660 has. Stihl decomp and wrist pin bearing would probably be a good start. Possibly OEM or another brand crank seals. OEM impulse and fuel lines if you will be running ethanol gas.
