Fleethirte
- 1:44 PM
- Apr 8, 2021
- Virginia
What pitch rim is that?
Decomp valve
Threaded hole?No sir, the little hole to the side. It it dosent go into the combustion chamber.
Threaded hole?
Attachment point for cylinder cover?
sounds like u need a toolset for crankcase assemblyI got the crankcase put together. Whew those bearing and the crankshaft are definitely bigger and stronger then the 660. I had a rough time trying to get the crank centered. I had to do a lot more then just tap the crank. Almost was going to find a press…
But I let some oil seep in overnight and finally got
It moved into the sweet spot this morning.
sounds like u need a toolset for crankcase assembly![]()
It probably has same issues that 660 has. Stihl decomp and wrist pin bearing would probably be a good start. Possibly OEM or another brand crank seals. OEM impulse and fuel lines if you will be running ethanol gas.Thinking about buying a 880 kit. Is there a list of parts that I need to buy so the saw will be dependable? What about the crank tool? Where can I get this. I would like to buy from a USA dealer. Is there a USA dealer who has all the better parts that need to be replaced?
