- 3:19 PM
- Feb 5, 2016
- Glenside Pa.
I wonder if the piston crown got damaged by a metal stop some time in the past. Perhaps using a 10mm bolt in the decomp? (I'm unfamiliar with the saw so I don't know if that is possible).
Once the crown got damaged, with a bit of raised metal to absorb heat and some hair line fractures in the crown, the piston became susceptible to a melt down.
Is that melted aluminum under the piston crown?
Yes it is. I believe that is what happened.
