HELP! Ms441c Reset Trouble
ManiacalMark
1:24 AM
PA
I believe what I did is the correct reset procedure. But, towards the end I never heard it clean up and run smooth, and now it idles higher like it’s not getting enough fuel.
Just got the saw not long ago so I’m not sure, guessing it needs a solenoid and filter.
hacskaroly
2100 Fanclub Member
10:24 PM
Northern Idaho, Ehh
I believe there are two different reset methods, and it depends on what year the saw is as to which one you use.
hacskaroly
2100 Fanclub Member
10:24 PM
Northern Idaho, Ehh
Here is a link to another post, there might be something in here that may help:
lehman live edge slab
Live Action
12:24 AM
Mn
All ms 441’s are version one saws so it’s 45-90 seconds idle and shut off without touching throttle. Yes it could use a solenoid if never been changed that saw will have a black one so you will put a green in with new orange fuel filter then do a reset and should he good to go. Depending on use or lack of use the pump parts may need changing also since it’s still a carb with diaphragms to pump fuel.
ManiacalMark
1:24 AM
PA
I don’t think anything has ever been done to it. Guy cut some firewood with it and cut one log job with it. Then it sat for who knows how long.
The orange fuel filter is top of my list since it has a regular black/white filter still.
