- 5:28 AM
- Jan 1, 2016
- Warren Center, PA
I'm starting with a straight gassed 310. The guy just wants it to run and I'm certain that I can make it run way better than stock.Is the goal here to see what this custom piston can do for a 039/390 or to see how strong you can build said saw? My point is that if you don't work from a known baseline, you have no idea what the piston actually did.
I'll clean up the 310 cylinder and keep it handy in case the am cylinder has issues but for as much as this saw will run I doubt there will be an issue.
