- 6:37 PM
- Jan 1, 2016
- Warren Center, PA
Thank you sir.I just measred, it' about .045
It has a nylon mesh filter
I've never put a tach on the nylon mesh filter saw. I'll get a pic of it tomorrow. It is very open.That may be an easier solution to the restrictive felt filter than building a bigger filter. Have you tried a high RPM test to see if there is a difference in max RPM?
The original 029 was 54cc, the 390 is 64cc - and they both run the same size filter. Add a muffler mod and a timing advance and the engine is trying to pull a lot more air in through that little filter.
HD11 or 16What carb do you like on these Terry?
I'm sure there will some difference between coils.
Fairy is close enough I guess...[emoji12]HD11 or 16
I know, my name is not Terry
I have zero Stihl parts laying around. If I get brave maybe I'll try those mods. Otherwise I'll try one of the carbs that Jeremy suggested. I know Dallas had good luck with a 044 carb on his 290.I made up my own carb using a Zama twin jet body and the shafts out of a 044 carb. I run 30/35 jetting.
The HD-5 that came on it isn't a bad carb if you are willing to do some mods - like block off the circuit from the main discharge nozzle to the low speed circuit, drill a hole from the wet side to just in front of the low speed needle seat to feed the low speed circuit and then open up the auxiliary jet to .35mm (I think that is what I used).
WOWFairy is close enough I guess...[emoji12]
IMHO, you can't tell much about the benefits of a higher compression piston if using them in an AM cylinder with inconsistent and greater than OEM squish. You're essentially defeating the purpose. All official testing should be performed on OEM cylinders so as to have some resemblance of a standard.
