- 10:59 AM
- Aug 3, 2024
- Oregon
I don't know how many know this but I have discovered another carburetor that can be used on the 361. A hd33 from a 270. Throttle linkage is the same and choke rod is working just fine as well as the bigger venturi like the HD14 or 17. Added benefit it already has the same impulse opening that the 361 originally has. The only modification I made is swapping over the top plate and using the same fuel line system as the 271. The 3 part that has in tank line, elbow and using a little bit of plain fuel line.
