TJ the Chainsaw Mechanic
Old Homelites rule!
- 5:46 AM
- Jan 7, 2016
- Next to my bench at the shop, Oregon
Hey guys, so I had a 391 come in that I was almost positive it was seized solid from straight gas. Turns out after checking the gas there was plenty of mix....removed the muffler and the cylinder and rings where barely broke in. Chain was duller than dull so I checked the air filter and it had fine dust, but luckily not much went through. Well a couple days past and I grabbed the saw to work on it and what would you know....sucker pull started and had great compression as if nothing happened! Huh, something wrong with the bottom end. Pulled the cylinder and the walls looked good. Little scoring from the fine dust that past the filter. Bearings all looked perfect...rings were fine. Called JD at stihl and told him what was going on and he said some of these saws had a bearing tolerance issue. We've sold many and this is the 1st. So, two new mains and rings are on order under warranty as this saw is about 3 months old. Just wondering how many of you guys have run across this.
