Philbert
Chainsaw Enthusiast
- 7:07 PM
- Jan 30, 2016
- East Dakota
(No Husqvarna jokes please!)
Was trying to help a friend whose STIHL MS260 would not start. Saw looked to generally be in good condition. Said it was running fine 'a few months ago'. Thought that I could help, being a 'saw guy'. ***All this was in the field***
SPARK, AIR, FUEL, and COMPRESSION (right?). Here is what I did:
- COMPRESSION: felt normal when pulling on the starter rope, and saw was reported to be running fine when last used.
- AIR: removed and inspected the air filter: used but pretty clean. Spark arrestor screen was clean.
- SPARK: checked for spark from the coil with an automotive type spark tester. Plug looked fine, but replaced it anyway, just in case. Checked the plug gap, and made sure that the 'kill switch' was not grounding out.
- FUEL: don't know how long fuel might have been left in the tank during some earlier period, but tank was mostly empty. Drained out the remaining fuel, replaced the fuel filter, and filled the tank half way with Tru-Fuel (canned, pre-mix, alcohol free stuff). Placed some fuel on the air filter with an eye dropper. Took the carb adjustment screws back to the starting points in the owner's manual. All these things done while pulling on the starter cord 20+ times after each thing tried. Tried some flooded saw starting techniques as well, even though fuel was never smelled. Never got a 'burp' or a 'bark'.
Again, this was in the field and not a shop setting. They are probably going to take it to the dealer. I am assuming something with the carb. Anything else someone could try, or look for in the field?
Thanks.
Philbert
Thanks.
Philbert
