MS201T C
Jimmy in NC
5:29 PM
North Carolina
The image in question...
Bottom right...needs a rebuild as it ate a locating pin.
At least yours is clean. Mine a dealer gave a bad diagnosis 4 years ago and they stored it under the house since then.
Its also an MS362C.
ucm931
5:29 PM
Michigan
Ten fo. Just making sure that there weren't bigger issues when that gets damaged. One of my saws has that cap protector cracked at the base and bent slightly toward the rear.
4:29 PM
I fixed a 461 for a guy that was busted off......and leaked oil thru a crack from the damage. But.....usually it's just cosmetic damage.
av8or3
5:29 PM
Waleska,Ga.
Jimmy , that coil will have to be set up (I believe) with the MDG1 after it’s installed. Didn’t think of it until now.
Jimmy in NC
5:29 PM
North Carolina
Hmmm. Well we will see shortly how it does out of the box. If it needs an MDG1 it will get one attached. Ill let you all know how it does...
