Lightning Performance
- 2:29 PM
- Jan 26, 2016
- East of Philly
I have a HLS Golf piston wearing Cabers in my MS362 non auto early edition saw. It took specking two pistons to get one that was round. I find this to be the major problem with AM pistons. Less so with OEM types. Short skirts and off size wrist pin sizes seem to be the norm. I used the OE everything but the actual piston. Everything fit very well in an A jug. It was haggard inside from lean seizure so I'm betting now it will be very close to a B jug inside. Ten plus tanks, so far so good. One small note Golf pistons are HEAVY. They can use some weight reduction. Mine is on a diet now. Watch your bare piston weight. The AM wrist pins are always heavier because they are NOT tapered inside the bore. The casting marks should be smoothed out a bit. Mine had no loose casting flashings. Check the clip bore seats they run the gamut of different sizes.
