MattG
Chainosaurus Rex
- 3:50 AM
- Apr 30, 2017
- Cambridgeshire, England
One of the local tree guys, bought a ms261c around a few days back.....wanted a new handlebar on it, after a log landed on it.
I mentioned to him that I'd read about loads of UK-side 261s meeting a premature death....something to do with the crank on the PTO side?? So anyway, I ordered a new needle cage for the PTO assembly, greased it and fitted it etc. etc.
But what I did notice is whilst the crank on his saw was fine, I did see signs of his old needle cage, starting to break up - basically very fine circular half and three-quarter rings of plastic from the ends of cage cylinder (I've chucked them out otherwise I'd upload a pic). I looked as if the butt end of cage was getting pushed around on the shaft and had started chaffing (against the washer?).
Anyway, this saw has a reputation for destroying cranks on the PTO side, right?
So I searched on AS, and found this:
https://www.arboristsite.com/community/threads/ms261-loose-clutch-drum.265634/
The needle bearing looked ok but I bought a new one that was superseded with a metal cage version as mine was plastic.
Does anyone know what the p/n of the superseded (i.e. updated!) metal one is?
The cage I replaced the one on Ben's is 9512 933 2260 and it's still the cr@ppy plastic one.... does anyone know of a better replacement? Or are stuck with just having to grease and replace the one on my mate's saw once or twice a year?
thanks Matt
thanks Matt
