Modding a Poulan Pro 475
Deets066
AKA Deetsey
7:11 AM
I don't think the intake is too bad seeing that it was only machined to be that low and not ground to be lower.
Still I bet you'd gain from some sort of crank stuffer
6:11 AM
Do you care to elaborate?
I'll try.
Too much intake hurts throttle response, idle and transition quality, and creates spitback. It also hurts primary compression.
What Deets is saying about stuffers is dead on in my humble opinion. With a reduction in case volume, you might get away with the long intake duration.
On the other hand, it could make the spitback aspect more pronounced.
A velocity stack would help that though.
GoBigBlue1984
Bluegrass Fart Knocker...
7:11 AM
Kentucky
I'll try.
I figured going in that idle would be wonky. It has been somewhat. I sent Joey a video of it before I put it in any wood (also before I did a little fine-tuning to the carb.) It would spool up very well and take a little longer than normal to come back. Even then, idle was slightly higher for 10 seconds before returning to normal range. But I may be able to correct that with a little more carb adjustment time. Maybe not. I like where Deets is going with a full circle crank. I also like the stack idea with a custom elbow.
This is not good stuff, this is great stuff. I freakin love it!!!!!!
More to come!!
Thank you Deeter and Randy.
6:11 AM
More to come!!
Any chance of using 576XP stuffers on other cranks?
Adirondackstihl
7:11 AM
Upstate NY
What do you guys think about a series of threads dedicated to one aspect of the engine?
Like a thread on exhaust height, port size, shape, effects, etc....
Another on intake.....then transfers, compression, pop-up pistons, etc.
^ I rike dis idea
