Milling saw mods
foragefarmer
70cc groupie
6:00 AM
Central, Va.
What all have you done and what have your experiences been?
I would think a muffler mod or adding a second port to a muffler would be good for a milling saw. I have a 394xp for milling and it got a fresh piston, base gasket delete, cleaned up the exhaust port due to a thick layer of carbon, port matched the muffler and added a second port to the muffler.
I honestly never ran the saw in stock form so I have no idea how it ran before, but I am pleased with the way it runs thus far. I have run a couple few gallons through it and pulled the muffler the other day and everything is in order.
Canadian farm boy
“Normal” people scare me.
6:00 AM
Ontario, Canada
I don't do any milling but I would imagine that an air filter upgrade would also be a benefit. Maybe a max flo filter or a v stack and a KnN.
mdavlee
Hillbilly grinder
6:00 AM
TN
The huskies don't need much help in the air filter department. I've done some porting to a few that are milling. Don't go crazy on compression or timing advance. A good muffler mod that directs it away is great.
foragefarmer
70cc groupie
6:00 AM
Central, Va.
What are you thinking of doing to that 395 you have when you get around to fixing it up?
mdavlee
Hillbilly grinder
6:00 AM
TN
Be some mild porting. No compression increase besides dropping the jug to set squish.
foragefarmer
70cc groupie
6:00 AM
Central, Va.
Squish on mine was still .028 after the gasket delete would you expect it to be similar for the 395? So just trim the base?
mdavlee
Hillbilly grinder
6:00 AM
TN
Shave the base and sand clearance if I over shoot it. I don't want 225 lbs of compression.
mdavlee
Hillbilly grinder
6:00 AM
TN
I've done several like that. All were 190-200. That's plenty for a milling saw. I may cut a taper on the chamber to open it a little more.
