Mcculloch sp125/101b kart saw build thread
p61 western
Ol Mudflap
11:01 AM
GFY
If it would fit I would!! The v4 is super tight! The reeds need to fit slightly into the block, the v6 is wider than the opening in the block, so I can’t do that and run a boot, I might space the carb and see how much room I can get under the box, then it might be possible, really want to see how this runs, if its disappointing, going to start really hacking!
Lol I know just had to give ya chit.
sawfun
11:01 AM
Portland Oregon
Been there as regards to the hacking. I was hoping you could show us a way without, but understand if thats not possible. I'd love to put WB under the hood without hacking.
Bigmac
11:01 AM
I have the carb fitted, and not hacked, some small details to finish, but not bad, the fuel inlet needs to be a 90°, not exactly sure the best route for that. The intake manifold needs to be custom, but I have that mocked up, the carb I have is a 1” bore and that’s bigger than the outside diameter of the stock manifold, so it really needs to be modified just to kinda work, I figured I would let it breathe a bit better with v4 reeds. The hole needs to be significantly enlarged for the carb, and the stock boot is way to small, once I have it all figured out I will post some info
Steve
Excellence!
1:01 PM
Should I have lied? Made up some crazy story of how it got sent out o Florida instead of California, and I almost didn’t get it back, and insurance wouldn’t cover it, but it showed up on my porch this vary moment?? Or I am an admitted slacker!! Lol
This story is much more entertaining! :D
redline4
I'm huge in Japan
1:01 PM
Rosholt Wisconsin
Add in an alien, a chupacabra and some aluminum foil and then you got a story!
Bigmac
11:01 AM
Got the call from Terry today, as it turns out the rod was bad, And as things would have it, Mike basically twisted my arm again and I chose to go with the built rod!
He said I should have it back by Wednesday!
p61 western
Ol Mudflap
11:01 AM
GFY
Lol it's a damn nice rod. You will be happy with it.
