- 7:54 PM
- Dec 24, 2015
- Coastal Oregon
Now you guys get two -
Such sweet music!!Now you guys get two -
Yer a brave man for leaving the clutch cover off....Now you guys get two -
For a second there I thought I heard the intro to "Hot for Teacher" by VanHalen.Now you guys get two -
Has anyone tried the Little Red Barn 125 piston, Mac part # 85539 i see them on ebay.
Not that i'm looking just curious.
We had a discussion on the 125C thread, I don’t think it will run, or if it does it won’t run well, it doesn’t have a keeper for the SP Circlip, It also has a hole that would flow transfer port volume out the exhaust port, it also looks like it’s set up for needle bearings in the piston, I’m not sure what the story is on it!Has anyone tried the Little Red Barn 125 piston, Mac part # 85539 i see them on ebay.
The standard 797 is the only boost port saw, maybe a few super 797 as well. The super 797 and early cp125 had the boss for the boost port. I think they deleted it just because it was just one less part to fail, and the small gain in a saw wasn’t worth the trouble. Just a guess. And with a fixed head they couldn’t machine them in like the kart 101. The mc101 had the same boost port window as the 797, and could easily machined in the fixed head saws, but once they switched to the double hump boost port, they changed the casting entirely for the sp125.Guys correct me if I am wrong, but the SP125's do not have boost ports right? Why do you think Mcculloch got away from them?
One of these days I would like to find an early mc101, I think it should have the lowest port timing, should be a good saw motor.
