Mastermind Revisits the MS661
4:08 AM
Yup, you nailed it. Now that I know more, I have so much more to learn.
But lets get back to your question Sir ....... Do YOU think case volume plays a role in higher exhaust or blowdown duration ?
Please elaborate what you know and what more you have learned
I've been trying for several years to get the 681 to really come alive. I'd tried everything under the sun.......more intake, less intake, more blowdown, less.....
Finally, I said F it and raised the hell out for the exhaust. My thinking was that if I had 81 on the intake, maybe rather than fight that, I'd embrace it and lengthen all the durations. It worked pretty well.
But what's that got to do with the 661?
5:08 AM
Now, is this a trend, we gonna start porting everything like this??? They seem to run very strong!
4:08 AM
Will that hurt long bar tourque ?
Not that I can tell with the 28".
Every configuration has to be done differently. There is no "everything" that can be done "like this". I'll be honest, I think I was swimming against the current on the 661. Everything I've learned tells me that it has too much intake, and too much exhaust. But, when you think about the case volume, the small size of the transfer ports (not at the upper end, but thru the passages), and the M-Tronic tuning system, this saw is far from a "normal" animal.
4:08 AM
Like on the Solo 681, rather than worry that I had far too much intake, I thought that if I have that much intake timing, maybe I need to take all the other numbers higher.
Well......I did that a few years ago, but I made a turd. This time I decided to increase all the durations......except the transfer duration. Instead of increasing transfer duration, I increased blowdown.
mdavlee
Hillbilly grinder
5:08 AM
TN
One of the strongest 7900/681'ive run has a high exhaust and low compression. Runs a 9 pin and 28" pretty easily.
I like higher exhaust. Most of my stuff was 2-8 degrees higher than what Randy has been doing.
Case capacity is easy to test with some fluids. Just have to level the case off. Put the crank at bdc. The other thing is the stuffer doohickey.
Keeping transfers smaller by whatever means will help velocity. Might be a pop up or even trimming the piston there. You just have to play with this stuff. Madsens gets 12-15% on a dyno over a stock 661. They cut the piston for their changes.
junkman
Crush it
2:08 AM
pacific northwest
This sounds like my jug Simon did ,it has 180 psi also ,transfers were not touched ,just intake and exhaust work done .
bryanr2
5:08 AM
USA
You might be surprised Mike. I'm chatting with Brad Snelling about it right now. I'm not good at keeping this stuff to myself. I want to see us all build great saws.
I sorta wanna see how the thinking in this thread goes before I let the cat out of the bag......
o_O:nusee::roto2lol:
Deets066
AKA Deetsey
5:08 AM
I like what ya did here Randy, 661 looks good. I have a little different look on porting now than I did a year ago.
I used to want to drop jug as far as possible to get compression. But now I'd rather get my machining closer to my desired port timing numbers so there is less grinding
Moparmyway
Its just a saw
5:08 AM
In a meeting
I agree 100% !!!
Great post !!
