- 12:19 AM
- Dec 3, 2015
- Banner Springs Tennessee
Smaller saws like a bunch of compression, the bigger ones don't seem to need as much.
How small kemosabe ?
From what I've seen.....which is always under review my me....60cc saws and smaller need more grunt. Compression makes grunt. Now, like any good thing, us saw junkies can overdo it. I'm not saying that they need 300psi to run.
What are small saws like that for ? climbing ?Ive gots me a 60cc saw that blows 177..its pretty sporty with a 20" barbut ive never tried it with anything bigger to see how strong it really is.
Ive got a 40cc saw that goes pretty hard too...
You're getting a little carried away hereWe need to stop and take a good look when a 81cc stock case/p&c will knock off a ported 90cc pro saw from the major two.
Not really. Watch the 681 and 661 videos. Pretty well same cut time at 20-21 seconds each cut in that log. He may have been around back when the 681 build happened on race saws as well. Everyone over ported and most were slower than stock.You're getting a little carried away here
Was that with the 1st or second cylinder?Last one I did is 98 120 83 180lbs
Very little grinding and it's a great runner. I like the higher exhaust
First one. Gonna try a high exhaust on the second. I'm impressed with how the first one runs.Was that with the 1st or second cylinder?
Found some bigger wood to try her out on. Dolmar is patiently waiting to get a workout lol
Alright keep testing!!!First one. Gonna try a high exhaust on the second. I'm impressed with how the first one runs.
Yes,What are small saws like that for ? climbing ?
Oops. Missed the stock part.While that may have been true back when, it certainly doesn't ring true with the latest 90cc saws, especially the ones coming from Missouri.
No disrespect to the stock 681, but put a 36" on it and it doesn't keep with any ported 90cc that I have.
If he would have compared stock to stock, I wouldn't have posted anything, but comparing a stock 681 to the latest ported 90cc Stihls ??????![]()
Like on the Solo 681, rather than worry that I had far too much intake, I thought that if I have that much intake timing, maybe I need to take all the other numbers higher.
Well......I did that a few years ago, but I made a turd. This time I decided to increase all the durations......except the transfer duration. Instead of increasing transfer duration, I increased blowdown.
One of the strongest 7900/681'ive run has a high exhaust and low compression. Runs a 9 pin and 28" pretty easily.
I like higher exhaust. Most of my stuff was 2-8 degrees higher than what Randy has been doing.
Case capacity is easy to test with some fluids. Just have to level the case off. Put the crank at bdc. The other thing is the stuffer doohickey.
Keeping transfers smaller by whatever means will help velocity. Might be a pop up or even trimming the piston there. You just have to play with this stuff. Madsens gets 12-15% on a dyno over a stock 661. They cut the piston for their changes.
madsen does better work than mr blue goo.Most of Madsen's work involes modifying the piston, and they turn out of a lot turds...
Once in a great while it works out but I'm not a fan of their worksaws having bought several brand new.
