Mastermind Meets The New MS362C Type II
Greenthorn
Least Informed OPE Member
11:35 AM
Southern Indiana
OK, although I am not knowledgeable in carbs and AV, for the life of me, I can't figure out why ANY carb would be mounted to the shroud frame or AV frame of any part of the saw???? What gives here...am I just that dumb? What am I missing or not seeing? Just asking...I know dumb questions are allowed, so I threw it out there.
Flip
6:35 PM
PIlot Mtn, NC
Did you notice if they snuck any aluminum bolts in there for weight savings?
5:35 PM
It's a pretty good mount system really. The rear carb support/air filter mount is held in place by two rubber bushings.
img_3291-jpg.10036
Glock37
6:35 PM
Monroeville Pa
Sent from my iPhone using Tapatalk[/IMG]
Greenthorn
11:35 AM
Southern Indiana
Gotcha in the understanding, I'm just still mad that mine leaked between the shroud and carb, and I want to blame it on stihl engineering! :tongue:
5:35 PM
That is pretty odd. Should be a tight fit there. I'll look closely at that. Might need some goop on it. :)
Miller Mod Saws
Chainsaw Masseuse
5:35 PM
Ravenwood,MO
For the geeks in the room......
NE Stock Numbers:
Ex: 100°
Transfers: Mains: 130° Secondaries: 128°
In: 71°
OE Stock Numbers:
Ex: 103°
Transfers: Mains: 130° Secondaries: 127°
In: 71°
The NE also has a redesigned combustion chamber.
Nice work my man. I'm one of the geeks looking at this post. Lol. Redisgned as maybe slightly smaller for more comp?
Duane(Pa)
It's the chain...
6:35 PM
Centre County
How's the quality of the NE jug? You see a bunch, so I wonder if you see an evolution in the way they're made.
5:35 PM
Not as deep, but but the squish band isn't as wide. I didn't notice it till I cut the squish bands.
All the newer jugs on both Stihl and Husky have a better finish than they once did. Tighter casting lines, slicker finish in the ports, etc.
weedkilla
8:05 AM
lobethal, South oz
So if I'm reading this correctly, this isn't a reinvention of the wheel, this isn't further evidence of the EPA ruining our favourite toys and the earths axis hasn't shifted dramatically.
A few tweaks that appear well considered that make the saw lighter, a few tweaks that may make the saw run presumably better when stock and all the likelihood of a ported 60cc saw that goes toe to toe with other ported 60cc saws. About right?
paragonbuilder
6:35 PM
Norwich, CT
NE Stock Numbers:
Ex: 100°
In: 71°
OE Stock Numbers:
Ex: 103°
In: 71°
So with the higher exhaust do we see slightly higher revving but a little less torque than the oe?
Or maybe the redesigned combustion chamber helped the higher exhaust achieve higher revs but maintain the torque?
Simondo
11:35 PM
UK
Stihl working Hard
Is it Friday yet
6:35 AM
Perth Australia
